[postgis-devel] [PostGIS] #925: [raster] ST_Transform
PostGIS trac at osgeo.org
Fri Jun 10 17:54:59 PDT 2011
 Reporter:  dustymugs       |       Owner:  dustymugs
     Type:  task            |      Status:  assigned
 Priority:  medium          |   Milestone:  PostGIS 2.0.0
Component:  postgis raster  |     Version:  trunk
 Keywords:  history         |
Comment(by robe):
 BBorie,
 Sorry I think I'm still having problems all the noise from my 9.1 build
 that always fails because of that issue with ST_MapAlgebra got me confused
 and also I think some of the tests past because I had put in some extra
 gdal environment variables like gdal-data, proj_lib and when I thought
 things were working I took them out.
 I did see 12s in there so I suspect one of those other env variables
 helped before.  I'm haunting that down.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/925#comment:54>
