[postgis-devel] [PostGIS] #1020: bug in BOX2DFLOAT4_in function due to GSERIALIZED_ON change
PostGIS trac at osgeo.org
Tue Jun 14 09:02:05 PDT 2011
  Reporter:  dustymugs  |       Owner:  pramsey
      Type:  patch      |      Status:  reopened
  Priority:  medium     |   Milestone:  PostGIS 2.0.0
 Component:  postgis    |     Version:  trunk
Resolution:             |    Keywords:
Changes (by dustymugs):
  * status:  closed => reopened
  * resolution:  fixed =>
Comment:
 I've attached another patch as the same sscanf call chokes on the format
 mask which is defined as float while the elements of GBOX are double.
 With this change (and yet to be commited patch for raster), the number of
 raster regressions drops to 2.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1020#comment:2>
