[postgis-devel] [PostGIS] #925: [raster] ST_Transform
PostGIS trac at osgeo.org
Tue Jun 14 13:04:55 PDT 2011
 Reporter:  dustymugs       |       Owner:  dustymugs
     Type:  task            |      Status:  assigned
 Priority:  medium          |   Milestone:  PostGIS 2.0.0
Component:  postgis raster  |     Version:  trunk
 Keywords:  history         |
Comment(by robe):
 Bborie,
 My regress test on 8.4 passed fine (the transform check), minus the 2 non
 transform failures you probably are also getting because of the
 GSERIALIZED changes.  I didn't close this out yet though because I wasn't
 sure if it was the path settings I had put in or the change in your
 regress tests.  So wanted to pull my path settings out before I close.
 Also that ST_MapAlgebra issue is making it difficult for me to test on my
 9.1 and 9.0 as most tests fail on those.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/925#comment:56>
