[postgis-devel] [PostGIS] #1023: topology regress failures related to GSERIALIZED: copytopology and
PostGIS trac at osgeo.org
Tue Jun 14 19:12:09 PDT 2011
 Reporter:  robe      |       Owner:  strk
     Type:  defect    |      Status:  new
 Priority:  high      |   Milestone:  PostGIS 2.0.0
Component:  topology  |     Version:  trunk
 Keywords:            |
 strk,
 On 8.4.4, 9.0.2, 9.1beta2 windows:
  copytopology gives regress failure -- might just be a rounding issue. The
 9.0.2 one fails in more spots.
 On 9.1beta2 both
  copytopology and createtopogeom tests fail.
 The createtopogeom seems harmless difference in line number error so you
 might just want to do your magic and strip the error numbers.
 I'm attaching the regress failure logs.
 Once this gets settled I think we are clean as far as our basic regress
 tests go.  Then we'll try to release another windows build for others to
 stress test and will do some more involved stress testing ourselves.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1023>
