[postgis-devel] [PostGIS] #1027: Hudson regress failing on sql-mm-circularstring test
PostGIS trac at osgeo.org
Wed Jun 15 19:20:55 PDT 2011
 Reporter:  robe     |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:  PostGIS 2.0.0
Component:  postgis  |     Version:  trunk
 Keywords:           |
 I'm sure others have noticed:
 Looks like might be a rounding issue possibly caused by our gserialized
 bbox to double maybe?
 --- sql-mm-circularstring_expected      2011-06-13 14:31:49.000000000
 -0700
 +++ /var/home/buildbot/opt/hudson/jobs/PostGIS-trunk-
 regression/workspace/results_8.4.5_3.2.2_4.7.0/test_37_out 2011-06-15
 17:10:38.000000000 -0700
 @@ -108,5 +108,5 @@
  public.circularstring.the_geom_3dz effectively removed.
  public.circularstring.the_geom_3dm effectively removed.
  public.circularstring.the_geom_2d effectively removed.
 -POLYGON((220187.382089758 150406.434743975,220187.382089758
 150506.717070259,220288.81590723 150506.717070259,220288.81590723
 150406.434743975,220187.382089758 150406.434743975))
 +POLYGON((220187.382089667 150406.434743975,220187.382089667
 150506.71707029,220288.815907205 150506.71707029,220288.815907205
 150406.434743975,220187.382089667 150406.434743975))
  npoints_is_null|
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1027>
