[postgis-devel] [PostGIS] #944: typmod support for PostGIS geometry
PostGIS trac at osgeo.org
Thu Jun 16 14:03:21 PDT 2011
 Reporter:  robe         |       Owner:  pramsey
     Type:  enhancement  |      Status:  new
 Priority:  medium       |   Milestone:  PostGIS 2.0.0
Component:  postgis      |     Version:  trunk
 Keywords:               |
Comment(by pramsey):
 Well, was almost as easy as expected... at r7409.
 None of the supporting PL/PgSQL functions has been touched, and right now
 geometry_columns is still a table while geometry_columns_v is the view.
 The view definition needs a slight fix as it is currently picking up a
 couple composite types as well as tables and views with geometry. Rubber
 will hit the road in deciding how to ditch the table.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/944#comment:24>
