[postgis-devel] [PostGIS] #1030: [raster] ST_SummaryStats on coverage crashes with the sample_percent parameter
PostGIS trac at osgeo.org
Thu Jun 16 14:13:04 PDT 2011
parameter
 Reporter:  pracine         |       Owner:  pracine
     Type:  defect          |      Status:  new
 Priority:  high            |   Milestone:  PostGIS 2.0.0
Component:  postgis raster  |     Version:  trunk
 Keywords:                  |
 SELECT *
 FROM st_summarystats('srtm_22_03_tiled_100x100', 'rast', FALSE);
 works, but:
 SELECT *
 FROM st_summarystats('srtm_22_03_tiled_100x100', 'rast', FALSE, 1.0);
 crashes with:
 ERROR:  rt_raster_from_wkb: wkb size < min size (61)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1030>
