[postgis-devel] [PostGIS] #1030: [raster] ST_SummaryStats on coverage crashes with the sample_percent parameter
PostGIS trac at osgeo.org
Fri Jun 17 08:17:12 PDT 2011
parameter
 Reporter:  pracine         |       Owner:  pracine
     Type:  defect          |      Status:  new
 Priority:  high            |   Milestone:  PostGIS 2.0.0
Component:  postgis raster  |     Version:  trunk
 Keywords:                  |
Comment(by dustymugs):
 I've refactored the set of ST_SummaryStats functions in r7410.  Your
 second example should fail as no ST_SummaryStats function should have a
 sample_percent parameter.  Only ST_ApproxSummaryStats functions have the
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1030#comment:3>
