[postgis-devel] [postgis-users] 1.5.3rc1
Paul Ramsey pramsey at opengeo.org
Fri Jun 17 11:54:40 PDT 2011
Also passes against 8.3 on OSX. Release in t-minus 24 hours if radio
silence holds.
P
On Thu, Jun 16, 2011 at 11:27 PM, Paragon Corporation <lr at pcorp.us> wrote:
> UPDATE - regression passes on our 8.3.15 Mingw install -- we were just
> missing the libconv-2 dependency in last tests.
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Paragon
> Corporation
> Sent: Friday, June 17, 2011 12:02 AM
> To: 'PostGIS Development Discussion'
> Cc: 'PostGIS Users Discussion'
> Subject: Re: [postgis-users] [postgis-devel] 1.5.3rc1
> Okay we tested with the tar ball.  Tar ball looks good.
> Works on our windows dev box against
> PostgreSQL 8.4.7, PostgreSQL 9.0.2 VC++ builds
> And regress tests pass
> However we are having a  battle getting the postgresql tests to pass on
> PostgreSQL 8.3.  I think this has more to do with the way Iwe are testing
> and some path setting we are missing than anything wrong with the packaging.
> For 8.4, 9.0 we are testing against the Enterprise Db VC++ builds, however
> the 8.3 Enterprise Db builds are no longer available on the site, and we
> have long since uninstalled that version from all our servers.
> Anyrate the 8.3 postgis-1.5.dll  builds, we just can't really test it at the
> moment and looking at the dependency doesn't give a clue as to what is
> missing.
> ----- TO WINDOWS USERS ---
> We'll put up the binaries in the next day or so for all 3, and if anyone
> with a PostgreSQL 8.3 install can confirm the binaries work okay, that would
> be great
> One other question and this is more of a question to Windows users:
> Does anyone mind if we package geos-3.3.0 instead of geos-3.2.2?
> Normally we package the latest minor of whatever release, but this poses
> problems if you have multiple PostGIS versions on the same PostgreSQL
> service in different databases.
> So if you are running PostGIS 1.5 or 1.4 and you are also running PostGIS
> 2.0 (development or final when it comes out),
> 1) The PostGIS 1.5 upgrade or PostGIS 1.4 upgrade would break your existing
> PostGIS 2.0 since they share the same GEOS and the newer PostGIS would cough
> up at an older GEOS.
> 2) The other reason is that non-critical performance only fixes are rarely
> backported to older GEOS.  So for example improvements in topological errors
> etc. you would miss out with a GEOS 3.2.
> The only reason to package a geos-3.2 instead of geos-3.3 is since there is
> less change, there is less chance of things like speed differences minor
> output differences adversely affecting you.
> Thanks,
> Regina and Leo
> http://www.postgis.us
> From: postgis-devel-bounces at postgis.refractions.net
> [mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of Paul
> Ramsey
> Sent: Thursday, June 16, 2011 1:53 PM
> To: PostGIS Development Discussion
> Subject: [postgis-devel] 1.5.3rc1
> Tagged
> http://svn.osgeo.org/postgis/tags/1.5.3rc1
> and bagged
> http://postgis.org/download/postgis-1.5.3rc1.tar.gz
> P.
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
> postgis-users mailing list
