[postgis-devel] [PostGIS] #1033: Installation for hard upgrade -- make easier to follow and get rid of obselete instructions
PostGIS trac at osgeo.org
Fri Jun 17 13:49:27 PDT 2011
 Reporter:  robe           |       Owner:  robe
     Type:  defect         |      Status:  new
 Priority:  medium         |   Milestone:  PostGIS 2.0.0
Component:  documentation  |     Version:  trunk
 Keywords:                 |
 Our hard_upgrad section seems a bit obsolete and just hard to follow.  If
 I'm on windows, I'm probably not going to be running perl for example so
 these instructions are pretty useless to me.
 http://www.postgis.org/documentation/manual-
 svn/postgis_installation.html#hard_upgrade
 I would like to get rid of the obsolete junk in hard-upgrade that applies
 to 8.0
 and also get rid of use of perl script so we have something that will work
 on all platforms.
 I'm proposing we just go with
 1) backup your old db before you install new postgis
 2) install new postgis
 3) create new postgis enabled database
 4) restore your backup on top of new database
 5) Run the uninstall_legacy.sql script (which I'm still finishing up)
 Does any one have issue with these instructions before I make the change?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1033>
