[postgis-devel] [PostGIS] #950: Topology: LayerTrigger - wrong filter
PostGIS trac at osgeo.org
Fri Jun 17 14:00:24 PDT 2011
 Reporter:  aperi2007  |       Owner:  strk
     Type:  defect     |      Status:  assigned
 Priority:  blocker    |   Milestone:  PostGIS 2.0.0
Component:  topology   |     Version:  trunk
 Keywords:             |
Comment(by aperi2007):
 strk,
 there was a few of time but at last I found the combination to cause the
 FAIL of trigger.
 select topology.DropTopology('t2');
 select topology.DropTopology('t1');
 select 'seq_reset', setval('topology.topology_id_seq', 1, false);
 select 't1', topology.CreateTopology('t1');
 insert into t1.node(geom, containing_face) values ('POINT( 0 0)', 0);
 create table t1.l1 (id serial);
 select 't1.l1',topology.AddTopoGeometryColumn('t1', 't1', 'l1', 'g',
 'POINT');
 insert INTO t1.l1(g) VALUES (topology.CreateTopoGeom('t1', 1, 1,
 '{{1,1}}'));
 select 't2', topology.CreateTopology('t2');
 insert into t2.node(geom, containing_face) values ('POINT( 0 0)', 0);
 insert into t2.node(geom, containing_face) values ('POINT( 1 1)', 0);
 create table t2.l1 (id serial);
 select 't2.l1', topology.AddTopoGeometryColumn('t2', 't2', 'l1', 'g',
 'POINT');
 insert into t2.l1(g) VALUES (topology.CreateTopoGeom('t2', 1, 1,
 '{{1,1}}'));
 -- the trigger FAILS because the t2.relation is not empty and should
 reject the delete
 delete from t2.l1;
 -- this next comand will remove the 't2' topology from topology.layer even
 if the t2.relation table is not empty.
 -- the trigger should be reject the delete comand with "A record in
 t2.relation still references layer..."
 delete from topology.layer where topology_id=2;
 Now I can build the regress test.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/950#comment:3>
