[postgis-devel] [PostGIS] #526: Define alias ST_Perimeter (for geography ST_Length)
PostGIS trac at osgeo.org
Fri Jun 17 20:43:24 PDT 2011
  Reporter:  robe     |       Owner:  pramsey
      Type:  defect   |      Status:  closed
  Priority:  medium   |   Milestone:  PostGIS 2.0.0
 Component:  postgis  |     Version:  trunk
Resolution:  fixed    |    Keywords:
Comment(by robe):
 Paul,
 Hope you don't mind -- I took the liberty of getting rid of one of your
 functions and changing to use default args instead.  Also did the same
 with ST_Length at r7418
Ticket URL: <http://trac.osgeo.org/postgis/ticket/526#comment:2>
