[postgis-devel] [PostGIS] #520: No check for different srid on operators when index is used
PostGIS trac at osgeo.org
Sat Jun 18 23:06:01 PDT 2011
 Reporter:  nicklas  |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:  PostGIS 2.0.0
Component:  postgis  |     Version:  trunk
 Keywords:           |
Comment(by robe):
 You are mistaken. What Nicklas is saying is that if you have an index --
 its ignore.  Here is a standalone example that I ran on 2.0 and didn't
 throw an error:
 CREATE TABLE tb1(gid serial primary key, geom geometry);
 CREATE INDEX idx_tb1_geom_gist ON tb1 USING gist(geom);
 INSERT INTO tb1(geom)
 SELECT ST_SetSRID(ST_Point(i,j),srid)
 FROM generate_series(-10,10,2) As i
     CROSS JOIN generate_series(-10,10,2) As j
     CROSS JOIN generate_series(4325,4326) As srid;
 SELECT a.gid As a_gid, b.gid As b_gid, ST_SRID(a.geom) As a_srid,
 ST_SRID(b.geom) As b_srid
  FROM tb1 As a, tb1 As b
 WHERE a.geom && b.geom
 Result is:
 a_gid  b_gid    a_srid  b_srid
 1       1       4325    4325
 1       122     4325    4326
 If I do this though:
    AND ST_SRID(a.geom) = 4325 AND ST_SRID(b.geom) = 4326;
 I do get an error of:
 ERROR:  Operation on two geometries with different SRIDs
Ticket URL: <http://trac.osgeo.org/postgis/ticket/520#comment:8>
