[postgis-devel] [PostGIS] #1037: geography: ST_Intersects, ST_DWithin gbox_overlaps: geometries have mismatched dimensionality
PostGIS trac at osgeo.org
Sun Jun 19 18:03:18 PDT 2011
 Reporter:  robe     |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:  PostGIS 1.5.4
Component:  postgis  |     Version:  1.5.X
 Keywords:           |
 Paul,
 Can you take a look at the attached query and let me know if it errors out
 for you.  I'm getting a lot of these errors with my California geometries
 when experimenting with geography.
 This fails on 1.5.2, 1.5.3 rc1, and 2.0.0 trunk.
 This particular polygon has 380 points (smallish in myset).  I've tried
 with smaller polygons and don't have the issue so not sure if its a number
 of points issue or not.  I've got some polygons with over 20,000 points
 also failing.  This is on a Windows 2008 R2 (64-bit running 32-bit
 PostgreSQL/PostGIS in case that matters).
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1037>
