[postgis-devel] [PostGIS] #1000: box3d_extent output is 2d, casted to box3d makes up random numbers
PostGIS trac at osgeo.org
Mon Jun 20 03:39:49 PDT 2011
 Reporter:  strk     |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:  PostGIS 2.0.0
Component:  postgis  |     Version:  trunk
 Keywords:  boxes    |
Comment(by mcayland):
 Thanks for the report. This looks like a particular solution, however I
 would much rather like to change the patch like this:
 out->zmin = in->zmin;
 out->zmax = in->zmax;
 And then ensure that zmax/zmin are set to zero when the box3d_extent is
 created. If you could rework your patch in this way then I am happy to
 review and commit it.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1000#comment:2>
