[postgis-devel] [PostGIS] #1046: Invalid geography polygons: BOOM! Could not generate outside point!
PostGIS trac at osgeo.org
Tue Jun 21 08:19:44 PDT 2011
 Reporter:  mwtoews         |       Owner:  pramsey
     Type:  defect          |      Status:  new
 Priority:  medium          |   Milestone:  PostGIS 2.0.0
Component:  postgis         |     Version:  1.5.X
 Keywords:  geography boom  |
Comment(by pramsey):
 No, it is a different issue. The point-in-polygon test in geography
 involves generating a point that is definitively outside the area, then
 counting the number of times the boundary intersects with the maybe-inside
 point. As you can imagine, the weakness is being to generate a point that
 is definitively outside of an arbitrary area on the sphere.
 This is more computational geometry and the work of ages.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1046#comment:2>
