[postgis-devel] [PostGIS] #1049: ST_SetBandNoDataValue change to use default args
PostGIS trac at osgeo.org
Tue Jun 21 23:51:51 PDT 2011
 Reporter:  robe            |       Owner:  pracine
     Type:  task            |      Status:  new
 Priority:  medium          |   Milestone:  PostGIS 2.0.0
Component:  postgis raster  |     Version:  trunk
 Keywords:                  |
 I've already updated the documentation as if it uses default args, but can
 you merge:
  st_setbandnodatavalue(rast raster, band integer, nodatavalue double
 precision, forcechecking boolean)
 precision)
 to just:
 precision, forcechecking boolean DEFAULT false)
 Also I forgot -- what exactly does the forcechecking argument do when set
 to true?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1049>
