[postgis-devel] [PostGIS] #1053: Make transformation and projection cache API available.
PostGIS trac at osgeo.org
Wed Jun 22 14:00:55 PDT 2011
 Reporter:  bnordgren    |       Owner:  pramsey
     Type:  enhancement  |      Status:  new
 Priority:  medium       |   Milestone:  PostGIS 2.0.0
Component:  postgis      |     Version:  1.5.X
 Keywords:               |
 Attached patch divides the projection cache API into internal and external
 pieces. The external piece uses an opaque type and wraps the internal
 type, performing the appropriate casts. The internal piece has been
 explicitly made static (it could not be used outside the file in which it
 was defined due to the function signatures containing structs also defined
 in that *.c file.)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1053>
