[postgis-devel] [PostGIS] #1051: Tiger Geocoder 2010 normalize_address bug - postDirAbbrev doesn't parse
PostGIS trac at osgeo.org
Wed Jun 22 17:17:08 PDT 2011
  Reporter:  mikepease       |       Owner:  robe
      Type:  defect          |      Status:  closed
  Priority:  critical        |   Milestone:  PostGIS 2.0.0
 Component:  tiger geocoder  |     Version:  1.5.X
Resolution:  worksforme      |    Keywords:
Changes (by robe):
  * status:  new => closed
  * resolution:  => worksforme
Comment:
 Mike I checked my current build and this works fine.  So I suspect you
 just need to update your geocoder.  In the tiger folder, there is an
 update_geocoder.bat script that should bring you up to date.  Give it a
 try.
 When I run these -- this is what I get:
 select * from normalize_address('212 3rd Ave N Minneapolis, MN 55401') ;
  address | predirabbrev | streetname | streettypeabbrev | postdirabbrev |
 internal |  location   | stateabbrev |  zip  | parsed
      212 |              | 3rd        | Ave              | N             |
 | Minneapolis | MN          | 55401 | t
 (1 row)
 select * from normalize_address('212 N 3rd Ave Minneapolis, MN 55401') ;
      212 | N            | 3rd        | Ave              |               |
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1051#comment:3>
