[postgis-devel] [PostGIS] #944: typmod support for PostGIS geometry
PostGIS trac at osgeo.org
Thu Jun 23 04:26:30 PDT 2011
 Reporter:  robe         |       Owner:  pramsey
     Type:  enhancement  |      Status:  new
 Priority:  medium       |   Milestone:  PostGIS 2.0.0
Component:  postgis      |     Version:  trunk
 Keywords:               |
Comment(by robe):
 BTW: I'm still for having both a geometry_columns and an
 st_geometry_columns, but my reason for both has changed.  As I said the
 st_geometry_columns is defined in the SQL/MM specs so if our objective is
 to move in that direction, I think we should have it.
 However, I now feel both should be views, but that geometry_columns should
 return the old form (uppercase -- POINT, POINT,POINT, POINTM), and
 st_geometry_columns should return the new format Point,PointZ, PointZM,
 PointM  (or should that be ST_Point... I forget).
Ticket URL: <http://trac.osgeo.org/postgis/ticket/944#comment:33>
