[postgis-devel] [PostGIS] #1051: Tiger Geocoder 2010 normalize_address bug - postDirAbbrev doesn't parse
PostGIS trac at osgeo.org
Thu Jun 23 13:38:01 PDT 2011
  Reporter:  mikepease       |       Owner:  robe
      Type:  defect          |      Status:  reopened
  Priority:  critical        |   Milestone:  PostGIS 2.0.0
 Component:  tiger geocoder  |     Version:  1.5.X
Resolution:                  |    Keywords:
Comment(by robe):
 No no comment, though that would be a good thing to add.  I can add a
 function or something that outputs the revision.  I'll double-check by
 reloading mine.  It might either be something I fixed locally that I
 didn't commit or something I broke that I commit.
 The 1.5.2 shouldn't be an issue.  I'm running on a 9.0 1.5.2 install for
 most of my tests.
 Thanks,
 Regina
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1051#comment:5>
