[postgis-devel] [PostGIS] #1061: [raster] Using a CTE causes process to fail
PostGIS trac at osgeo.org
Fri Jun 24 14:36:33 PDT 2011
 Reporter:  dustymugs       |       Owner:  pracine
     Type:  defect          |      Status:  new
 Priority:  blocker         |   Milestone:  PostGIS 2.0.0
Component:  postgis raster  |     Version:  trunk
 Keywords:                  |
 The following query causes the postgresql process to abort.
 WITH foo AS (
         SELECT
                 ST_AddBand(
                         ST_MakeEmptyRaster(10, 10, 10, 10, 2, 2, 0, 0,-1)
                         , 1, '64BF', 0, 0
         AS rast
 SELECT rast FROM foo
 The crash relates to the ST_AddBand as the following does not cause an
 abort.
 WITH foo AS (
         SELECT
         AS rast
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1061>
