[postgis-devel] [PostGIS] #1074: Matching on different street spelling?
PostGIS trac at osgeo.org
Tue Jun 28 13:42:05 PDT 2011
 Reporter:  mikepease       |       Owner:  robe
     Type:  defect          |      Status:  new
 Priority:  medium          |   Milestone:  PostGIS 2.0.0
Component:  tiger geocoder  |     Version:  1.5.X
 Keywords:                  |
 Do you think there is anything you can do to find matches on slightly
 different spellings of street names?
 One case of this is when a compound name is spelled with a space in the
 middle.  For example:
 COTTAGE WOOD instead of COTTAGEWOOD
 --this works great[[BR]]
 select (addy).*,*
 from geocode('8525 COTTAGEWOOD TERR, Blaine, MN 55434')
 --But an alternate spelling of COTTAGE WOOD throws it WAY off[[BR]]
 select (addy).*,*
 from geocode('8525 COTTAGE WOOD TERR, Blaine, MN 55434')
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1074>
