[postgis-devel] [PostGIS] #1077: Regression tests for tiger geocoder
PostGIS trac at osgeo.org
Tue Jun 28 20:08:37 PDT 2011
 Reporter:  robe            |       Owner:  robe
     Type:  task            |      Status:  new
 Priority:  high            |   Milestone:  PostGIS Future
Component:  tiger geocoder  |     Version:  1.5.X
 Keywords:                  |
Description changed by robe:
Old description:
> Now that we are making so many changes to tiger geocoder I fair breaking
> things.  Thus need to start writing up regression tests.
> Normalize_address is easy since most of what is needed for normalize can
> run with just raw tiger data loaded.
> Geocode is harder since it needs real data so we might have to setup
> samples.
> Speed is important since any minor change we make can significantly
> impact speed, and that is even trickier to regress since its so dependent
> on database setup.
> Anyrate we'll just start setting up tests and hand test them as we make
> changes until we've got a better idea.
New description:
 run with just the pre-packaged  lookup tables loaded.
 samples.
 Speed is important since any minor change we make can significantly impact
 speed, and that is even trickier to regress since its so dependent on
 database setup.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1077#comment:1>
