[postgis-devel] Rework ticket #855 - pgsql2shp fields conversion from predefined list
Mark Cave-Ayland mark.cave-ayland at siriusit.co.uk
Wed Jun 29 15:43:14 PDT 2011
On 27/06/11 18:01, Mark Cave-Ayland wrote:
> Just a heads-up - I'm in the process of re-working the above commit
> since it misses some fundamental points with respect to the new code
> structure (for example ShpDumperCreate() should only be used to build a
> state structure from a configuration structure, not do actual work).
> I hope to be able to commit a revised version of this patch later this
> evening.
Okay - it took a bit longer than expected, but this is now done. Please
test and make sure I haven't accidentally broken anything.
ATB,
Mark.
Mark Cave-Ayland - Senior Technical Architect
PostgreSQL - PostGIS
Sirius Corporation plc - control through freedom
http://www.siriusit.co.uk
t: +44 870 608 0063
Sirius Labs: http://www.siriusit.co.uk/labs
