[postgis-devel] [PostGIS] #1084: Revise populate_geometry_columns and AddGeometryColumns to have optional use_typmod argument (typmod support)
PostGIS trac at osgeo.org
Thu Jun 30 17:23:32 PDT 2011
 Reporter:  robe      |       Owner:  robe
     Type:  task      |      Status:  new
 Priority:  critical  |   Milestone:  PostGIS 2.0.0
Component:  postgis   |     Version:  trunk
 Keywords:            |
 The plan for these: again a continuation of #944
 1) They will no longer add/delete entries to the geometry_columns since
 that now reads from constraints and system catalogs
 2) They will have an options use_typmod which we will default to true.
 Anyone wanting the old constraint behavior will have to pass in a false
 for second argument.
 IF typmod is chosen, will create geometries using form
 ALTER TABLE ... ADD COLUMN geometry(PointZ,4326)  etc.
 If constraint is chosen, will do as before just creating an unadorned
 geometry with check constraints
 3) Will accept both old format name and Paul's new fangled names.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1084>
