[postgis-devel] [PostGIS] #575: ST_Union fails on a group of linestrings.
PostGIS trac at osgeo.org
Mon Mar 7 09:31:10 PST 2011
  Reporter:  jeffadams78  |       Owner:  pramsey
      Type:  defect       |      Status:  closed
  Priority:  medium       |   Milestone:  PostGIS 1.5.3
 Component:  postgis      |     Version:  1.5.X
Resolution:  fixed        |    Keywords:
Changes (by jadams):
 * cc: jadams (added)
Comment:
 strk: Yes upgrading to the GEOS trunk fixes it.
 For others who want to try this:
 1. Download the trunk from http://geos.osgeo.org/snapshots/
 2. tar -xvfj the file
 3. configure, make, sudo make install
 4. Remove the existing libgeos-3.2.2.so, libgeos_c.so, libgeos_c.so.1
 files from /usr/lib, replace with libgeos-3.3.0.so, libgeos_c.so, and
 libgeos_c.so.1 files from /usr/local/lib.
 5. Restart postgresql.
 6. Verify you now are using GEOS 3.3.0 by running "SELECT
 postgis_full_version()".
Ticket URL: <https://trac.osgeo.org/postgis/ticket/575#comment:4>
