[postgis-devel] [PostGIS] #762: [raster] Raster some check fails
PostGIS trac at osgeo.org
Thu Mar 10 06:39:42 PST 2011
 Reporter:  aperi2007       |       Owner:  pracine
     Type:  defect          |      Status:  assigned
 Priority:  critical        |   Milestone:  PostGIS 2.0.0
Component:  postgis raster  |     Version:  trunk
 Keywords:                  |
Comment(by strk):
 Ah, it's my ~/.psqlrc setting min_client_messages to DEBUG.
 The test script should make sure min_client_messages is set to the default
 instead, or that the users's .pgsqlrc isn't used.
 Porting the whole infrastructure onto the run_test of core should include
 such facilities, I've extended it recently to allow testing topology,
 doing the same for raster shouldn't be too much work
Ticket URL: <http://trac.osgeo.org/postgis/ticket/762#comment:9>
