[postgis-devel] [PostGIS] #851: [raster] Numerous ST_Value query cause the memory to grow indefinitely
PostGIS trac at osgeo.org
Tue Mar 15 07:27:45 PDT 2011
 Reporter:  pracine         |       Owner:  pracine
     Type:  defect          |      Status:  new
 Priority:  critical        |   Milestone:  PostGIS 2.0.0
Component:  postgis raster  |     Version:  trunk
 Keywords:                  |
Comment(by jorgearevalo):
 I don't really find the meaning of the three fist lines of
 "get_rt_context"
 rt_context ctx = 0;
 MemoryContext old_context;
 if ( ctx ) return ctx;
 As strk said, seems that ctx was a static variable sometime in the past,
 but now the third line has no sense.
 Pierre, did you find any problem with get_rt_context? Do you have a log?
 I'm trying to reproduce it before applying the suggested changes (make ctx
 static, replace palloc by malloc).
Ticket URL: <http://trac.osgeo.org/postgis/ticket/851#comment:9>
