[postgis-devel] [PostGIS] #659: shp2pgsql crashing when trying to load into geography order sensitive
PostGIS trac at osgeo.org
Fri Mar 18 08:46:32 PDT 2011
  Reporter:  robe     |       Owner:  pramsey
      Type:  defect   |      Status:  closed
  Priority:  medium   |   Milestone:  PostGIS 2.0.0
 Component:  postgis  |     Version:  trunk
Resolution:  fixed    |    Keywords:
Changes (by jadams):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 Fixed in trunk revision 6922.  The -G was attempting to set a default
 column name and accidentally freeing the old column name when it
 shouldn't.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/659#comment:1>
