[postgis-devel] [PostGIS] #779: shp2pgsql -S option seems to fail, and is missing in doc
PostGIS trac at osgeo.org
Fri Mar 18 08:52:54 PDT 2011
  Reporter:  nicklas  |       Owner:  jadams
      Type:  defect   |      Status:  closed
  Priority:  medium   |   Milestone:  PostGIS 1.5.3
 Component:  postgis  |     Version:  1.5.X
Resolution:  fixed    |    Keywords:
Changes (by jadams):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 Resolved in trunk in revision 6922.
 -S now creates POINTS from MULTIPOINT shapefiles.
 If you have one POINT in a MULTIPOINT shapefile, that's the bug described
 in #864.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/779#comment:6>
