[postgis-devel] [PostGIS] #748: shp2pgsql use wrong schema name
PostGIS trac at osgeo.org
Fri Mar 18 11:36:48 PDT 2011
 Reporter:  aperi2007  |       Owner:  pramsey
     Type:  defect     |      Status:  new
 Priority:  medium     |   Milestone:  PostGIS 2.0.0
Component:  postgis    |     Version:  trunk
 Keywords:             |
Comment(by jadams):
 I committed the regression test (which passes on linux).  I did not commit
 the code change for that one line because I don't want to change it if it
 doesn't fix the problem.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/748#comment:22>
