[postgis-devel] [PostGIS] #748: shp2pgsql use wrong schema name
PostGIS trac at osgeo.org
Fri Mar 18 12:25:01 PDT 2011
 Reporter:  aperi2007  |       Owner:  pramsey
     Type:  defect     |      Status:  new
 Priority:  medium     |   Milestone:  PostGIS 2.0.0
Component:  postgis    |     Version:  trunk
 Keywords:             |
Comment(by jadams):
 I removed the -m1 parameter.  It was to ensure grep only read one line
 from the .opts command-line-options-for-the-test file, but you shouldn't
 ever have more than one non-comment line anyway so if you put two and it
 breaks, no big deal.  There didn't seem to be a "max-lines" option in your
 MinGW grep.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/748#comment:24>
