[postgis-devel] [PostGIS] #748: shp2pgsql use wrong schema name
PostGIS trac at osgeo.org
Fri Mar 18 13:16:15 PDT 2011
 Reporter:  aperi2007  |       Owner:  pramsey
     Type:  defect     |      Status:  new
 Priority:  medium     |   Milestone:  PostGIS 2.0.0
Component:  postgis    |     Version:  trunk
 Keywords:             |
Comment(by robe):
 Well its still failing and so is the Latin1 test.  I'll put that not on
 the other.  I'm not sure if they are true failures quite yet.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/748#comment:27>
