[postgis-devel] [PostGIS] #748: shp2pgsql use wrong schema name
PostGIS trac at osgeo.org
Fri Mar 18 13:23:53 PDT 2011
 Reporter:  aperi2007  |       Owner:  pramsey
     Type:  defect     |      Status:  new
 Priority:  medium     |   Milestone:  PostGIS 2.0.0
Component:  postgis    |     Version:  trunk
 Keywords:             |
Comment(by jadams):
 Does the actual output look correct?  If the error message says the diff
 that failed was "blah\blah\test_19_diff" then "blah\blah\test_19_out" will
 have the output.
 I notice one of the diff commands in run_test uses "-u" and one does not,
 -u is something to do with ignoring CRs, so maybe we need -u in all
 places?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/748#comment:28>
