[postgis-devel] [PostGIS] #748: shp2pgsql use wrong schema name
trac at osgeo.org
Fri Mar 18 14:58:11 PDT 2011
Reporter: aperi2007 | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Keywords: |
Comment(by jadams):
I also had nls_build = no, but I just tried changing it to yes and that
didn't make a difference. I cannot reproduce the problem on linux, I don't
know if it is specifically MingW or if there is some situation I'm just
not replicating.
I may have to look more at this once I'm back at the office and have a
windows machine I can develop on. I need to debug it more actively than is
possible via comments on a ticket ;-). Thanks for your help so far!
Ticket URL: <http://trac.osgeo.org/postgis/ticket/748#comment:35>
