[postgis-devel] [PostGIS] #748: shp2pgsql use wrong schema name
PostGIS trac at osgeo.org
Fri Mar 18 14:32:46 PDT 2011
 Reporter:  aperi2007  |       Owner:  pramsey
     Type:  defect     |      Status:  new
 Priority:  medium     |   Milestone:  PostGIS 2.0.0
Component:  postgis    |     Version:  trunk
 Keywords:             |
Comment(by robe):
 Okay that helped -- this is the error (after I put in your fix)
 SET
 SET
 BEGIN
 ERROR:  invalid byte sequence for encoding "UTF8": 0x8b
Ticket URL: <http://trac.osgeo.org/postgis/ticket/748#comment:33>
