[postgis-devel] [PostGIS] #748: shp2pgsql use wrong schema name
PostGIS trac at osgeo.org
Fri Mar 18 14:11:36 PDT 2011
 Reporter:  aperi2007  |       Owner:  pramsey
     Type:  defect     |      Status:  new
 Priority:  medium     |   Milestone:  PostGIS 2.0.0
Component:  postgis    |     Version:  trunk
 Keywords:             |
Comment(by jadams):
 If you edit regress/Makefile and move this test after all the other
 loader/foo tests, its output won't get overwritten any more.  Let me know
 if that gives you anything more to go on.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/748#comment:32>
