[postgis-devel] [PostGIS] #808: shp2pgsql and encoding, something must be wrong
PostGIS trac at osgeo.org
Fri Mar 18 14:10:08 PDT 2011
  Reporter:  nicklas  |       Owner:  pramsey
      Type:  defect   |      Status:  closed
  Priority:  medium   |   Milestone:  PostGIS 2.0.0
 Component:  postgis  |     Version:  trunk
Resolution:  fixed    |    Keywords:
Comment(by robe):
 well it works if I correct the expected file and set encoding to latin 1.
 So its the expected itself that is the problem.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/808#comment:17>
