[postgis-devel] [PostGIS] #808: shp2pgsql and encoding, something must be wrong
PostGIS trac at osgeo.org
Fri Mar 18 13:32:22 PDT 2011
  Reporter:  nicklas  |       Owner:  pramsey
      Type:  defect   |      Status:  closed
  Priority:  medium   |   Milestone:  PostGIS 2.0.0
 Component:  postgis  |     Version:  trunk
Resolution:  fixed    |    Keywords:
Comment(by robe):
 You know what's bizarre the  test_22_out looks like the right output
 (Tårneby in Våler I Solør kommune).  So not sure where that other is
 coming from.  It might actually be an issue with the encoding of the
 expected file or the comparing. So I think this might be a false negative.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/808#comment:13>
