[postgis-devel] [PostGIS] #748: shp2pgsql use wrong schema name
PostGIS trac at osgeo.org
Fri Mar 18 13:45:57 PDT 2011
 Reporter:  aperi2007  |       Owner:  pramsey
     Type:  defect     |      Status:  new
 Priority:  medium     |   Milestone:  PostGIS 2.0.0
Component:  postgis    |     Version:  trunk
 Keywords:             |
Comment(by robe):
 This one has just loader.err as output.   It has no associated diff I can
 see so I presume that means it is not getting to the select?
 When I look at loader file - I see the insert is actually for the Latin
 one not this one so perhaps that means it didn't work.  Unfortuantely I
 had dropped my regress database.  I'll inspect that in a minute.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/748#comment:29>
