[postgis-devel] [PostGIS] #792: [raster] Addband regresssion test fail on some systems.
PostGIS trac at osgeo.org
Sun Mar 20 07:02:24 PDT 2011
  Reporter:  pracine         |       Owner:  pracine
      Type:  defect          |      Status:  closed
  Priority:  blocker         |   Milestone:  PostGIS 2.0.0
 Component:  postgis raster  |     Version:  trunk
Resolution:  fixed           |    Keywords:
Changes (by jorgearevalo):
  * status:  assigned => closed
  * resolution:  => fixed
Comment:
 post-install-check executed and correct. I close this ticket (open if
 needed)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/792#comment:7>
