[postgis-devel] [PostGIS] #752: Add to topology readme the grants to do
PostGIS trac at osgeo.org
Mon Mar 21 03:46:50 PDT 2011
  Reporter:  aperi2007    |       Owner:  strk
      Type:  enhancement  |      Status:  closed
  Priority:  medium       |   Milestone:  PostGIS 2.0.0
 Component:  topology     |     Version:  trunk
Resolution:  fixed        |    Keywords:
Changes (by strk):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 I've added a line recommending not to forget about permissions.
 Not sure the README should say more than that.
 Which grants you want to give is really up to you. I wouldn't necessarely
 give all permissions on topology.topology and topology.layer for example.
 It is the same with the rest of postgis, isn't it ?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/752#comment:1>
