[postgis-devel] [PostGIS] #879: ST_ModEdgeSplit using deprecated function
PostGIS trac at osgeo.org
Mon Mar 21 22:40:32 PDT 2011
 Reporter:  robe      |       Owner:  strk
     Type:  defect    |      Status:  new
 Priority:  medium    |   Milestone:  PostGIS 2.0.0
Component:  topology  |     Version:  trunk
 Keywords:            |
 SELECT topology.ST_ModEdgeSplit('ma_topo',  3,
 ST_SetSRID(ST_Point(227594,893910),26986)  ) As result;
 Gives error:
 ERROR:  function line_locate_point(geometry, geometry) does not exist
 LINE 1: SELECT line_locate_point(oldedge.geom, apoint)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/879>
