[postgis-devel] [PostGIS] #881: ST_ExtrudePolygons
PostGIS trac at osgeo.org
Tue Mar 22 21:14:17 PDT 2011
 Reporter:  robe         |       Owner:  pramsey
     Type:  enhancement  |      Status:  new
 Priority:  medium       |   Milestone:  PostGIS Future
Component:  postgis      |     Version:  trunk
 Keywords:               |
 Not sure this is the best name of it or if there is an SQL-MM function
 defined for it.
 The basic idea is given a building foot print (as polygon or multipolygon)
 and a height return a polyhedron using the height to extrude up the
 polygons
 Kind of like described here:
 http://www.rgi-otb.nl/3dtopo/documents/RGI-011-151.pdf
Ticket URL: <http://trac.osgeo.org/postgis/ticket/881>
