[postgis-devel] [PostGIS] #883: [raster] Make every rtpostgis.sql function immutable strict when possible
PostGIS trac at osgeo.org
Wed Mar 23 12:11:23 PDT 2011
 Reporter:  pracine         |       Owner:  pracine
     Type:  task            |      Status:  new
 Priority:  medium          |   Milestone:  PostGIS 2.0.0
Component:  postgis raster  |     Version:  trunk
 Keywords:                  |
 The only exception to this should be when a default parameter can not be
 determined when calling the function.
 We must make sure that EVERY functions accepting NULL parameter check for
 null with if (PG_ARGISNULL(0)) in rt_pg.c. STRICT functions do not have to
 do such a check.
 Exceptions:
 -ST_AddBand(torast raster, fromrast raster, fromband int, toband int)
 because a default value for toband can not be determined before calling
 the function. Could be replaced by "ST_NumBands(rast) + 1" though...
 -ST_AddBand(rast raster, index int, pixeltype text, initialvalue float8,
 nodataval float8) because nodataval can be NULL meaning do not set a
 nodata value.
 -Every ST_Intersects functions
 -Every ST_SetValue functions because NULL means set to nodata
 Changed to STRICT:
 -ST_MakeEmptyRaster series
 -ST_AddBand plpgsql variants
 -ST_HasNoBand(rast raster)
 -ST_BandIsNodata SQL variants
 -ST_BandPath(raster)
 -ST_BandPixeltype(raster)
 -All ST_Value fucntions
 -ST_BandNodataValue(raster)
 -ST_BandMetadata SQL variant
 -ST_PixelAsPolygon
 Still to review:
 -ST_MapAlgebra(rast raster, band integer, expression text, nodatavalueexpr
 text, pixeltype text) nodatavalueexpr could be replaced by '' in the
 variants and pixeltype by ST_BandPixelType(rast, band). I don't know if
 this is bad in terms of performance.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/883>
