[postgis-devel] Contributing code to PostGIS Raster
Jorge Arévalo jorge.arevalo at deimos-space.com
Wed Mar 23 16:15:35 PDT 2011
On Wed, Mar 23, 2011 at 11:56 PM, David Zwarg <dzwarg+postgis at azavea.com> wrote:
> 2011/3/23 Jorge Arévalo <jorge.arevalo at deimos-space.com>
>> On Wed, Mar 23, 2011 at 4:30 PM, Pierre Racine
>> <Pierre.Racine at sbf.ulaval.ca> wrote:
>> >>Yes, I think it's the best way. A generic ST_AsGDALRaster and several
>> >>wrappers around it.
>> > Was there anything implemented yet? Could Bborie take over? So you could
>> > focus on the GDAL driver (and tickets)?
>> rt_raster_dump_as_wktpolygons transform a PostGIS Raster in a GDAL
>> Raster using VRT driver. This is the closest implemented reference for
>> Bborie right now, I think.
> Hello,
> I filed some additional information in #870 about
> rt_raster_dump_as_wktpolygons. It specifically will speed up the dual loops
> inside of that function, and reduce the number of features created and
> destroyed.
> It would be worth investigating that approach before using the current
> method as a template of other functions.
> Thanks,
> David
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
Hi David,
You're right. Your suggestion is a good point to improve the function.
I'll work on it the next two days, before working on #851. Bborie,
when will you be able to start working?
Best regards,
Jorge Arévalo
Internet & Mobilty Division, DEIMOS
http://es.linkedin.com/in/jorgearevalo80
http://mobility.grupodeimos.com/
http://gis4free.wordpress.com
http://geohash.org/ezjqgrgzz0g
