[postgis-devel] Contributing code to PostGIS Raster
Bborie Park bkpark at ucdavis.edu
Wed Mar 23 16:19:26 PDT 2011
>> Hello,
>> I filed some additional information in #870 about
>> rt_raster_dump_as_wktpolygons. It specifically will speed up the dual loops
>> inside of that function, and reduce the number of features created and
>> destroyed.
>> It would be worth investigating that approach before using the current
>> method as a template of other functions.
>> Thanks,
>> David
>> postgis-devel mailing list
>> postgis-devel at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-devel
> Hi David,
> You're right. Your suggestion is a good point to improve the function.
> I'll work on it the next two days, before working on #851. Bborie,
> when will you be able to start working?
> Best regards,
Hey Jorge,
If you want, I'll wait until you've done with possibly improving
rt_raster_dump_as_wktpolygons.  I'm currently familiarizing myself with
the PostgreSQL/PostGIS/Raster source.
-bborie
Bborie Park
Programmer
Center for Vectorborne Diseases
UC Davis
530-752-8380
