[postgis-devel] What to return when refering to an invalid band number
Pierre Racine Pierre.Racine at sbf.ulaval.ca
Thu Mar 24 16:13:32 PDT 2011
The question is more “returning an error or a warning (with null values)…” I will deal with the message text…
From: Mateusz Loskot [mailto:mateusz at loskot.net]
Sent: 24 mars 2011 19:11
To: Pierre Racine; PostGIS Development Discussion
Subject: Re: [postgis-devel] What to return when refering to an invalid band number
Pierre,
What about returning "band index is out of range" for any
invalid band index?
Regards,
Mateusz Łoskot, http::/mateusz.loskot.net
(Sent from my mobile)
----- Reply message -----
From: "Pierre Racine" <Pierre.Racine at sbf.ulaval.ca>
Date: Thu, Mar 24, 2011 22:37
Subject: [postgis-devel] What to return when refering to an invalid band number
To: "PostGIS Development Discussion" <postgis-devel at postgis.refractions.net>
Right now if I do this query on a raster having only one band:
 SELECT ST_Value(rast, 0, 1, 1) FROM myraster
I get "ERROR:  RASTER_getPixelValue: Invalid band index (must use 1-based)"
If I do:
 SELECT ST_Value(rast, 2, 1, 1) FROM myraster
I get "NOTICE:  Could not find raster band of index 2 when getting pixel value. Returning NULL"
and a NULL value.
The answer should be the same if I ask for band 0 or band 2 but which one? An error or a warning with a NULL (or a set of NULL for a tiled coverage)?
This symptom is generalised to every other function getting band properties (st_bandnodatavalue, st_bandpixeltype, etc...).
Pierre
postgis-devel mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20110324/1e5bbe0f/attachment.html>
