[postgis-devel] [PostGIS] #894: _ST_Expand for geography is broken
PostGIS trac at osgeo.org
Thu Mar 31 11:30:33 PDT 2011
 Reporter:  robe     |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  blocker  |   Milestone:  PostGIS 2.0.0
Component:  postgis  |     Version:  1.5.X
 Keywords:           |
Old description:
> I think this may be related to #869.
> In trying to trace the cause of failure of ST_DWithin in 869, I
> discovered that
> _ST_Expand for any geography type for any distance always returns the
> same geography.  What was especially puzzling is that it is also broken
> in PostGIS 1.5.2 and yet the ST_DWithin in that works.
> _ST_DWithin by itself works fine and produces the correct answers in that
> regress for both 2.0 and 1.5.2 -- so the failing part is the _ST_Expand.
> My conclusion is that while PostGIS 1.5.2 is also broken, the cached box
> it produces must be right, but that when Paul enable the gserialized, it
> somehow probably made the cached box agree with the output geometry thus
> making the _ST_Expand ineffective in 2.0.
> I'm not sure how to see the cached box of a geography though?  Do we have
> a function for that?
> So here is the case:
> On PostGIS 1.5.2 and PostGIS 2.0
> SELECT ST_AsText(_ST_EXPAND(ST_GeogFromText('LINESTRING(1 2, 3 4)'), 1000
> -- result--
> LINESTRING(1 2,3 4)
> However watch this:
> SELECT _ST_EXPAND(ST_GeogFromText('LINESTRING(1 2, 3 4)'), 1000) &&
> ST_GeogFromText('POINT(3 3)');
> On 1.5 the above returns true, but on our new 2.0 after Paul's changing
> the switch to make gserialized live, it now returns false.
> So PostGIS 2.0 is more or less more or less broken than 1.5. It's just
> that 1.5 is covering its tracks in ways we usually check.
New description:
 In trying to trace the cause of failure of ST_DWithin in 869, I discovered
 that
 _ST_Expand for any geography type for any distance always returns the same
 geography.  What was especially puzzling is that it is also broken in
 -- result--
 LINESTRING(1 2,3 4)
 However watch this:
 -- This returns true in both --
 SELECT _ST_EXPAND('LINESTRING(1 2, 3 4)'::geography, 1000) && 'POINT(3
 3)'::geography);
 --- This returns true in PostGIS 1.5 and false in PostGIS 2.0 --
 SELECT 'POINT(-20 -10)'::geography && _ST_Expand(ST_GeogFromText('POINT(0
 0)'),3000000);
 -- This works in both --
 SELECT _ST_Expand('POINT(-20 -10)'::geography,3000000) &&
 ST_GeogFromText('POINT(0 0)');
 So perhaps its expanding 0 0 that is at fault, but both are still
 producing erroneous geography output from _ST_Expand which doesn't agree
 with what is happening.
Comment(by robe):
 Oops I was incorrect in the second part of my assumptions. I guess it is
 the expansion of 0 0 that is problematic because if I switch the expand it
 works.  But notice the geography expand output is still wrong in both.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/894#comment:1>
